Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart How-to's/Installations > 04-06 Lancer Ralliart How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 5, 2008, 01:24 AM   #1
Personal Sales Rating: (0)
Drives: 06 Lancer Ralliart
o2 sensor on downpipe...
I ordered in the header/downpipe with CEL eliminator from RRM and am curious how easily (or not) the o2 sensor in the downpipe is removed and replaced back into RRM's. Also how exactly is the CEL eliminator installed?
Offline
Old Jan 5, 2008, 10:11 AM   #2
Personal Sales Rating: (5)
Jameson_IXMR's Avatar
Drives: an evo duh?
Our evos have 2 o2 sensors, one at the downpipe and another after the cat converter. The first one is just for ECU fuel trimming, but the second one detects the o2 after it passes through the cat. If it is the same as the first o2 sensor it will toss a CEL because that would indicate the cat is bad/missing whatever. A CEL fix is usually also called an O2 simulator, and probably connects to the wiring going to that SECOND O2 sensor, allowing you to remove the sensor all together. It pretends that things are normal and sends a signal back to the ECU saying everything is A-ok.
It seems like you could just toss in a resister in place of the second o2 sensor, but apparently the sensor lets out the signal at a certain hertz(frequency) somewhere between .4 and .8 volts I belive, which could be fairly hard to replicate. I imagine the O2 CEL fix you bought is a device like that, which would consist of a timer circuit to randomize variables such as frequency and really simulate the output of the stock o2 sensor. Hope that helps, good luck.
edit: I didnt see this was a reg. Lancer forum, but Im 99% sure that it's pretty much the same.
Offline
Old Jan 5, 2008, 03:17 PM   #3
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
Get yourself an O2 sensor socket from the auto parts store, it'll keep you from rounding off the sensor. Other than that, it's not hard to remove. The CEL eliminator just screws onto the 2nd O2 sensor and then into the exhaust pipe.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Offline
Old Jan 5, 2008, 05:20 PM   #4
Personal Sales Rating: (8)
Drives: your mom crazy with my striking good looks
look in the advanced DIY forum for a better solution.
__________________
wtb 4g69 bottem end. pm me.
Offline
Old Jan 7, 2008, 11:45 AM   #5
Personal Sales Rating: (29)
Drives: 2005 Mr. Evo Eight
Send a message via AIM to bruce988jl
I just bought a specific box wrench to the right size... I didn't bother with a O2 sensor socket though I have used one and It works nicely. The hardest part with the install is trying not to strip the O2 sensor when installing/removing it to/from. A tip with installing the O2 sensor, pre-wind it the opposite direction that you'll be turning in so that you don't overwind the wires. I think like.. maybe 6-7 turns should be fine.
__________________
New to the Ralliart forum? Got some questions about your car and its compatibility? Check out the Noob Thread and you'll find a lot of your answer there!
Offline
Old Jan 7, 2008, 06:56 PM   #6
I've always used a big crescent wrench, never had any problems. of course, my o2 sensors have been removed a few times
__________________
Offline
Old Jan 11, 2008, 03:53 PM   #7
Personal Sales Rating: (7)
ski10804life's Avatar
Drives: 2004 Ralliart Turbo
Send a message via AIM to ski10804life
This might be a little late hav'nt been on her ein a while but i had the sensor wrench or what ever it is and it deff did'nt work i torre the threads appart and had to buy a new one to put in my new downpipe do be carfule. Alot of the times your exhaust gets so hot that it welds itself to the pipe threads then your screwed like it did to mine.
__________________
2004 Turbo Ralliart
Custom T4 turbo kit
Road///Race sway bar and perches
Road///Race CF engine cover
Tein S-Tech springs
SplitSecond ECU
BLitz BLM gauges
Raze R-74 17x7, Toyo Proxy4 wrapped
My car FOR SALE http://forums.evolutionm.net/sale-ca...art-300hp.html
*FOR SALE* -
Apexi S-AFC II special edition
EVO8 plug and play harness
(PM me for details)
Offline
Old Jan 12, 2008, 11:28 AM   #8
Drives: an evo duh?
Use the proper size tools (I had a friend who used to use standard on metric because "It fits!". Oh god. Anyway the right wrench and a 2 dollar 3 foot PVC plumbing pipe from home depot will do the trick.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
