Feb 1, 2005, 07:06 AM
Personal Sales Rating: ( 0)
Drives: 04 Ralliart,92 TSi AWD
Free mods: Removing intake silencer
I am sure you have all seen the little hump/box on the unterside of you stock intake.this box IS removable and is EMPTY.All it does is silence the intake and soak up heat(which is not benificial in any way).
1- Remove intake by removing little push pins on front frame.to do this you must have a small flat head screw driver to pull them up OR you can push them down.then lightly pull up and pull intake tube towards you.
2- pop out silver pins by taking a small screwdriver and a hammer or whatever is handy and place small screwdriver in hole on silver pin and hit it.this may take a few minutes.to remove them completely you MUST have a pair of needle nose pliers.once pin is pushed thru ( screw driver should be nearly all the way down) use pliers and pop the pins.
** optional..get a plug from a auto parts store or a piggy bank and cover hole
3.slide intake tube back in and replace the black push pins.you are now done and should have a slightly louder intake as well as cooler air flowing thru for better performance gains.
this mod should get a gain of 1-5 HP as cooler air will be flowing into your intake. heres some pics.. sorry if they are a little blurry.
__________________
~04 Ralliart- New Toy
My little Braket Queen
92 TSiAWD- My Baby
Very selfish and she doesnt play nice!
Offline
Feb 1, 2005, 07:32 AM
more pics..
__________________
92 TSiAWD- My Baby
Offline
Feb 1, 2005, 11:23 AM
Personal Sales Rating: ( 1)
Drives: 2004 RA Silver
nice pictures but i doubt you will get 1-5 hp from this..
-joe
Offline
Feb 1, 2005, 11:50 AM
Drives: Ralliart
what's the sound like? any difference?
1-5hp??? not sure about that.
__________________
GA///RA
NO! It's not an EVO! But I still kicked yo @$$!
2004 Mitsubishi Lancer Ralliart
"Ya know why, dude? 'Cause we're a f*%kin' tripod!"
Offline
Feb 1, 2005, 02:39 PM
Slightly louder.Its more of a throatier soand and you can hear the air get sucked in when you hit the throttle cable while the hood is up. It brings in more cold air thus the SLIGHT hp increase.. I am estimating it since I havent dyno'd my car yet and I have a piggyback now too so its gonna be hard to tell with mine.But from prior experience with cars the colder the air the more HP gains.thats why I said 1-5. 1 being the minimum and MOST LIKELY and 5 bieng the very best...at any rate its a helpful free mod.
__________________
92 TSiAWD- My Baby
Offline
Feb 1, 2005, 02:43 PM
Drives: 02 LancerOZ, 89 Turbo 5-speed minivan
maybe more like .2hp
__________________
2002 Lancer
Offline
Feb 1, 2005, 04:03 PM
Drives: Ralliart
Quote:
yup!
Offline
Feb 1, 2005, 06:02 PM
Personal Sales Rating: ( 2)
Drives: Ralliart
Isn't that small box just a safety in case water gets in the intake?
__________________
RRM Turbo Kit,Stage 3 CM clutch,Autovation Pedals, Kartboy SS, Kartboy Bushings, Accolade grills, RRM cat-back, RRM lower tie bar, RRM Swaybar+Perches, RRM Clutchline, Gramlight 16" 57S W/ BFG KDW, ES Tails, Perrin Antenna, Defi BF Gauges (OP,WT,OT)
Offline
Feb 1, 2005, 07:29 PM
Drives: 2004 Mitsubishi Lancer Ralliart
Quote:
I think he's talking about the intake resonator. Technically it's just there to kill the loud sound of an intake, taking it off will make the intake louder and may add a miniscule amount of Hp. However on my lanos, i only noticed a very tiny amount of performance. maxing out 3rd gear (auto) had a better acceleration... thats it.
__________________
DeeJay Krens
Future Mods:
RRM Body Kit
VRS Custom Exhaust (3", Stainless Steel, Magnaflow Resonator/hi-flow Cat, Megan Racing Spec II C/F muffler)
RRM Turbo Kit
Kartboy Short Shifter
RRM Flywheel
Boe's Fuel Rail
Future Tinkering:
Nos, and Custom Internals.
GenMivec ... Join Us!!!
Offline
Feb 1, 2005, 11:21 PM
Drives: 2004 Black Ralliart
will this void warrenty?
Offline
Feb 2, 2005, 06:36 AM
i doubt that it increases any hp or decreases the temp, since you are still getting air from the same place
-joe
Offline
Feb 2, 2005, 10:49 AM
That box gets really hot.. Whatever air goes in there gets hot.I took mine off and it was all Cold air goin in the intake. thats all.
And HE is a SHE.. I am a chick guys.. Please dont call me a he. thanks
__________________
92 TSiAWD- My Baby
Offline
Feb 2, 2005, 11:20 AM
Quote:
Nope.. Shouldnt.Unless its provable that doing that caused a major problem ( and it wont) you should have no problems.My dealership didnt even notice it and I was jsut there today.
__________________
92 TSiAWD- My Baby
Offline
Feb 2, 2005, 12:48 PM
Drives: Ralliart
The box gets hot? Everything in the engine bay gets hot so your really just pulling in hot air. The only way to get cold air would be through a CAI or somthing that pulls in air from directly under the car or through say the fog light housing.
Either way it's still a free mod. By the way it's pretty hard to tell your a she from typing
__________________
Offline
Feb 2, 2005, 07:47 PM
whatever floats your boat i guess.. i don't think this will do anything imho
-joe
Offline
Tags
08, 2005, 206, air, exhaust, horsepower, intake, lancer, louder, make, mods, ralliart, remove, removing, resonator, silencer  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
